grandMoulin's avatar
grandMoulin
Initiate
Dec 25, 2021
restart one PoE port with SNMP on GS510TP using good OID/MIB
I have found how to restart just one PoE port (the 6th amoung 8) with SNMP on Netgear GS510TP and it must work with many others switches (1 is for up and 2 is for down) :
snmpset -c private [my.ip] 1.3.6.1.4.1.4526.11.16.1.1.1.3.1.6 i 2 && snmpset -c private [my.ip] 1.3.6.1.4.1.4526.11.16.1.1.1.3.1.6 i 1
get all your port status with :
snmpwalk -c public [my.ip] 1.3.6.1.4.1.4526.11.16.1.1.1.3.1
(this is done externally with just port 161 redirected with TCP)
thanks to msi with that response from GS110TP
hope this helps too
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    grandMoulin
    Thank you for sharing this here in the community. :)  This will help a lot.
    DaneA
    NETGEAR Community Team
ProSupport for Business
