rhenriksen's avatar
rhenriksen
MIB for GS510TP (again)
I found the conversation below, but unfortunately the download links for the MIB were 48 hour lifespan.
a) why the finite lifespan? Why not make the MIBs accessible all the time?
b) could I get a link for the MIB?
https://community.netgear.com/t5/Smart-Plus-Click-Switches/MIB-for-GS510TP/m-p/1233418/thread-id/5209
Out of all the GS510TP switches we've deployed in enclosures out around the campus, one is consistently going offline and needing to be rebooted. It's running the latest software. I'm hoping to get some more metrics on its performance, to see if there's a temperature issue or something.
  • JohnC_V's avatar
    JohnC_V
    Jul 06, 2017
    rhenriksen,
    Just to answer your question that why is it that the other switches has the MIB files posted on our support site. As our engineering team says that those switches are just working as standard. No MIB files needed in order for the SNMP to work. They also tried checking it and it doesn't need any MIB files to work.
    It seems that I already sent you the MIB files, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi rhenriksen,
    We can still provide you the MIB for your GS510TP. But MIB files are per request, as we are not posting this to our support site. I'll just send you a pm once I got the MIB file.
    • rhenriksen's avatar
      rhenriksen
      Thanks; don't have a PM yet, that I can see.
      Why the policy against posting the MIBs for download?
      • JohnC_V's avatar
        JohnC_V
        rhenriksen,
        Some of the switches MIB files are actually per request. My apologies. We will try to add it also on our support site so that our community will benefit to it. But I cannot guarantee it. I am still waiting for the MIB file.
ProSupport for Business
