NickC44
Dec 20, 2016Aspirant
mib troubles
I am trying to find out the rssi and bssi of a WNAP320, but cannot seem to get my network monitor app (Intermapper) to recognize the particular OID. I have loaded the correct mib file, and can pull some basic info out via snmp, but what I really want is the stationrssi object, which I believe is 1.3.6.1.4.1.4526.100.7.9.8.1.1.10.0. The value it returns is null.
Any help is appreciated. Thanks.
Hi Nick
Hope there is no obstacles or any interferences betweek two buildings. You can use third party application such as inssider to find out signal strength. .
http://www.metageek.com/products/inssider/
Regret to inform you that Our current firmware do not support remote AP signal strength in WDS mode.
Thanks
Raghu
- RaghuHRNETGEAR Expert
Hi Nick44
Tested in v3.5.20.0 firmware. Able to get associatedBSSID and StationRSSI through MIB browser.
Following are the OIDs
Associated BSSID - .1.3.6.1.4.1.4526.100.7.9.8.1.1.6
Station RSSI - .1.3.6.1.4.1.4526.100.7.9.8.1.1.10We are getting those information under
stationList -> stationListTable -> stationListEntry -> associatedBssid / stationRssi
- NickC44Aspirant
Thanks for the response, RaghuHR. I just upgraded the firmware on both units (operating in bridge mode) to 3.5.20.0, and made sure I was using the WNAP320_v3.5.20.0.mib file, but still cannot get any info from section 8 "station list". I can get info from earlier sections (e.g., 5.1.1), so I know I'm formatting the OID correctly. Both 8.1.1.6 and 8.1.1.10 return "NoSuchName" no matter what I do. =(
