NickC44
Dec 20, 2016Aspirant
mib troubles
I am trying to find out the rssi and bssi of a WNAP320, but cannot seem to get my network monitor app (Intermapper) to recognize the particular OID. I have loaded the correct mib file, and can pull ...
- Jan 02, 2017
Hi Nick
Hope there is no obstacles or any interferences betweek two buildings. You can use third party application such as inssider to find out signal strength. .
http://www.metageek.com/products/inssider/
Regret to inform you that Our current firmware do not support remote AP signal strength in WDS mode.
Thanks
Raghu
NickC44
Dec 22, 2016Aspirant
Thanks for the response, RaghuHR. I just upgraded the firmware on both units (operating in bridge mode) to 3.5.20.0, and made sure I was using the WNAP320_v3.5.20.0.mib file, but still cannot get any info from section 8 "station list". I can get info from earlier sections (e.g., 5.1.1), so I know I'm formatting the OID correctly. Both 8.1.1.6 and 8.1.1.10 return "NoSuchName" no matter what I do. =(
