NickC44
Dec 20, 2016Aspirant
mib troubles
I am trying to find out the rssi and bssi of a WNAP320, but cannot seem to get my network monitor app (Intermapper) to recognize the particular OID. I have loaded the correct mib file, and can pull ...
- Jan 02, 2017
Hi Nick
Hope there is no obstacles or any interferences betweek two buildings. You can use third party application such as inssider to find out signal strength. .
http://www.metageek.com/products/inssider/
Regret to inform you that Our current firmware do not support remote AP signal strength in WDS mode.
Thanks
Raghu
NickC44
Dec 29, 2016Aspirant
Hi RaghuHR. Thanks for sticking with me.
The WNAP320 is acting as a bridge and not an AP on purpose, as I have other APs to cover the building. I didn't want to reduce the range/power/etc. by also enabling client association. I am trying to connect two buildings across a street approximately 130' apart. I tried using the internal antenna (tested with units mounted horizontally and vertically) but was not getting very good throughput, so I attached a pair of yagi antennas* from a previous system but there was no improvement. I was hoping to use the rssi number to adjust the antenna alignment in the hopes of improving to maybe 5Mbps or more. Associating my laptop with the WNAP320 as a client won't provide this information.
Thanks again. Nick
*directional yagi antenna, 14 dBi, 802.11g, 2.4gHz
ETA:
I just discovered that iReasoning MIB Browser can show the actual values of the fields. Unfortunately, something is still preventing the return of any value from the vapStatusTable (1.3.6.1.4.1.4526.100.7.9.7.5) and stationListTable (1.3.6.1.4.1.4526.100.7.9.8.1) -- they just return "no data available". I can get everything up to 1.3.6.1.4.1.4526.100.7.9.7.4.1.25 (wlanNormalDisconnectTotal), and after 1.3.6.1.4.1.4526.100.7.9.9. Does this issue have to do with WDS being activated without Client Association?
RaghuHR
Jan 02, 2017NETGEAR Expert
Hi Nick
Thanks
Raghu
- NickC44Jan 02, 2017Aspirant
Okay, thanks Raghu. I appreciate you help with this issue.
Nick
