rhenriksen's avatar
rhenriksen
MIB for GS510TP (again)
I found the conversation below, but unfortunately the download links for the MIB were 48 hour lifespan.   a) why the finite lifespan? Why not make the MIBs accessible all the time? b) could I get ...
  • JohnC_V's avatar
    JohnC_V
    Jul 06, 2017
    rhenriksen,
    Just to answer your question that why is it that the other switches has the MIB files posted on our support site. As our engineering team says that those switches are just working as standard. No MIB files needed in order for the SNMP to work. They also tried checking it and it doesn't need any MIB files to work.
    It seems that I already sent you the MIB files, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
