rhenriksen
Jun 25, 2017Aspirant
MIB for GS510TP (again)
I found the conversation below, but unfortunately the download links for the MIB were 48 hour lifespan. a) why the finite lifespan? Why not make the MIBs accessible all the time? b) could I get ...
- Jul 06, 2017
Just to answer your question that why is it that the other switches has the MIB files posted on our support site. As our engineering team says that those switches are just working as standard. No MIB files needed in order for the SNMP to work. They also tried checking it and it doesn't need any MIB files to work.
It seems that I already sent you the MIB files, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jun 28, 2017NETGEAR Employee Retired
Hi rhenriksen,
We can still provide you the MIB for your GS510TP. But MIB files are per request, as we are not posting this to our support site. I'll just send you a pm once I got the MIB file.
- rhenriksenJul 03, 2017Aspirant
Thanks; don't have a PM yet, that I can see.
Why the policy against posting the MIBs for download?
- JohnC_VJul 04, 2017NETGEAR Employee Retired
Some of the switches MIB files are actually per request. My apologies. We will try to add it also on our support site so that our community will benefit to it. But I cannot guarantee it. I am still waiting for the MIB file.
- JohnC_VJul 06, 2017NETGEAR Employee Retired
- rhenriksenJul 06, 2017Aspirant
So, are you saying that the GS510TP MIB doesn't expose any additional metrics that wouldn't otherwise be available w. a generic MIB from, say, Paessler's PRTG application?
