boe's avatar
boe
Luminary
Aug 01, 2020
S3300 - console cable?
Hello,   According to the website, the console connection is on the back.   It certainly doesn't look like it would connect to a standard DB9 or RJ45.    Can someone tell me where to get the consol...
  • DaneA's avatar
    Aug 02, 2020
    boe
    The console port  of the S3300 switch models is for debugging purposes only by NETGEAR Support and it requires a special adapter.  As reference, kindly checked pages 14 and 18 of the S3300 Hardware Installation Guide here.
    Also, as far as I have researched, there is no option and no link to buy or to get that special adapter.
    DaneA
    NETGEAR Community Team
ProSupport for Business
