boe
Feb 28, 2021Luminary
S3300 or GS752TPSB?
Hello, I've been working with the S3300 for years and like them but they don't have enough POE power and are about 2 10g ports short of what I need these days. The tech specs on the GS752TPSB a...
DaneA
Mar 01, 2021NETGEAR Employee Retired
boe,
The tech specs on the GS752TPSB are either diliberately vague or just poorly worded. How many of the ports on it are 10g?
The GS752TPSB does not have any 10G ports. As reference, kindly check the GS752TPSB data sheet here.
Anyone know of a model very similar to the S3300 with more poe power coming out soon?
Are you referring to the PoE/PoE+ budget? If yes, you can check on the GS752TPP which has a PoE+ Budget of 760W. To know more about the specification of the GS752TPP, kindly check its data sheet here.
DaneA
NETGEAR Community Team
