boe's avatar
boe
Luminary
Aug 01, 2020
S3300 - console cable?
Hello,
According to the website, the console connection is on the back.   It certainly doesn't look like it would connect to a standard DB9 or RJ45.    Can someone tell me where to get the console cable / parts to console into an S3300?
  • boe,
    The console port  of the S3300 switch models is for debugging purposes only by NETGEAR Support and it requires a special adapter.  As reference, kindly checked pages 14 and 18 of the S3300 Hardware Installation Guide here.
    Also, as far as I have researched, there is no option and no link to buy or to get that special adapter.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    boe,
    DaneA
    • boe's avatar
      boe
      Luminary
      That is truly a shame.   The S3300 seems to be a great switch and I've deployed several.    I recently had one deployed that I did not have a backup of handy.   I couldn't access it via the assigned IP even I set my PC with an IP on that subnet.   A console would have been extremely handy.    Hopefully they'll come out with something to replace the S3300 with a real console port - usb, db9 or Rj45 that isn't just for diagnostics.
ProSupport for Business
