SidHarberbridge's avatar
Jul 27, 2024
S350 Series GS324TP
Home LAN basically as shown in diagram. Has been working well for a couple of years using an unmanaged 8-port Linksys (LGS108P). 8-ports no longer enough, so I'd like to replace switch with a Netgea...
  • schumaku's avatar
    schumaku
    Jul 27, 2024
    Looks like the switch was powered-on before it was connected to your router Ethernet or LAN port.
    The DHCP client does not endlessly wait or repeat the DHCP attempt endlessly. At that point it will fallback to the default LAN IP address which is 192.168.0.239/24. The most easy way is toggling the power while connected to the router resp. the LAN.
ProSupport for Business
