BarrLynd
Mar 26, 2025Tutor
Scheduled reboot of Smart Managed Switch
Hi all, Apart from buying an Netgear Insight subscription, is there a way of rebooting a whole switch on a schedule? In particular at one client, I have a GS752TPv3 which seems to lose ports afte...
Mar 27, 2025Guru - Experienced User
If the switch seems to be experiencing problems, I would delve into why that's happening. Switches shouldn't need to be rebooted. If it does then something is causing the problem.
Has the switch been factory reset and setup from scratch and tested to see if it fails?
Does it fail with a limited amount of connections to the switch?
