JamesKP
Jul 05, 2024Follower
Netgear GS316PP scheduled reboot
Forgive me if this is a very silly question.
Is it possible to schedule a weekly reboot cycle with this product?
I imagine it being unmanaged would mean no, really not sure of the difference between managed and unmanaged switches.
Thanks,
James
Thanks,
James
JamesKP wrote:
Is it possible to schedule a weekly reboot cycle with this product?Hi James,
What issues you expect to be magically addresses by a power cycle this fully unmanaged PoE+ switch? keep in mind there are no controls beyond of the LEDs and the power resp. the physical connections. This is what an unmanaged switch is...
Sure, you could consider adding an inexpensive power switch with timer to the AC side of the switch, or disconnect an Ethernet/PoE cable on regular base - but this is it then.
-Kurt.
1 Reply
-Kurt.
