Troubleshooting
102 TopicsNetgear Switch G5316v3
I setup a new home network and it worked for 3 mins then it stopped. Nighthawk MS80 system Modem connected to Mesh Router which is connected to Netgear G5316V3 16 port unmanaged switch which i then connected to CAble Matters 24 port Shielded RJ45 Patch Panel. Currently only have 7 confimed working ethernet lines to 2 TV's, Xbox, 2 PC's. 1 not used. When i set it all up and powered up, it all worked. Ethernet lines lasted about 5 mins then stopped. The error msg being shown is there is no internet signal. The wifi still works.However my ethernet cables no longer have internet signal. The Switch lights are all blinking and power is on. When i power cycle the switch the internet does not come back, however all the ports are blinking like its sending data. Is this Switch toast?94Views0likes2CommentsMS308 unstable connection
Hello, I just upgraded my old 8 ports Netgear Switch for the newer MS308. When Doing this I also upgraded my ethernet cables from Cat 5(e) to Cat8. Problem I have that since moving to this new switch my internet has gone up in speed (was 940mb/s) but down in consistency. Normally I have a 1.1GB connection with an 12ms ping but very frequently it drops down to 500mb and sometimes even loses connection (Google not loading). I used some of the old cables (which i know work) and exchanged the cable from my PC to the switch (it still happened) and also replaced the cable from the switch to the wall (it still happened), no success. I also moved the incoming and outgoing cables to a different port on the switch, which also doesn't make difference. You would think 500mb/s is plenty but I just got out of a conference call that kept dropping me and also paused the video of my 3 colleagues reporting bad internet connection. Any suggestion what else I can do? Does it look like something is wrong with the MS308 (like I think there is)?Solved761Views0likes11CommentsNo internet after switch is plugged in
I have a GS305v3 unmanaged switch that I just bought and attempted to use. It is connected to my internet via cat6 cable that I ran from my office in my house where my router/modem is located, to my bedroom. When I connect any device to the ethernet port that I put in the bedroom, I have no issues connecting to the internet. But if I plug the switch into the port, then any device to the switch, no internet is passing through. All lights on the switch illuminate as they should according to the manual, but I can't seem to find any info as to what the problem possibly is. For a clear picture of how all the hardware is set up: Fiber internet direct to router/modem in office Cat6 cable to ethernet port in office Cat6 cable from office ethernet port to bedroom ethernet port through the attic Any device connected directly to ethernet port in bedroom works perfectly with 1000mbps+ download Switch plugged direct to ethernet port, devices plugged into switch, no internet to any devices Any advice would be greatly appreciated and thank you in advance to anyone who offers advice.1.6KViews0likes17CommentsGS105 troubleshooting - ports seem to not be working
Just bought a GS105 and it will power on (green light stays on), however, it doesn't seem to want to send/recieve anything through any of the ports. I have tested the cable via my mac > my ankr hub > ethernet port in the wall, and it can connect. It seems to lose it when it goes through the switch. The Port with the cable going from the switch to the ethernet wall port has both lights green/flashing occasionally. Super lost here. Using cat6 cables, just wired cat6 from my router up to my wall in my office as well, so all relatively new wiring/in good shape. The connections on my network tab within my settings just show the ethernet connections under other services rotating places (while still remaining not connected). Any suggestions would be super appreciated.766Views0likes1CommentProblems moving from GS108 to GS116v2
I replaced an old GS108 to a GS116v2 and my home network became unusable both proximal (before) and distal (after) to the switch. Very slow and intermittent dropped signals. The green lights are flashing as if there is activity but my network became useless. I switched back to the GS108 and everything is fine again. I need the extra ports of the 116 so maybe I’ll need to buy another 108? Any advice would be appreciated.630Views0likes4CommentsGS605v5 - my wi-fi is working, but my computer's ethernet connection hasn't worked for days
My ISP is Spectrum. My modem (and their tests) indicate that I'm getting service. I have a Netgear switch that relays things to my Wi-Fi mesh system and to my PC. I've never had trouble with it before. But a few nights ago, the ethernet connection on my computer stopped working (so I had to switch to Wi-Fi, which is still working). Since then I've contacted Spectrum, tried a few random tricks I found online to try to reset or diagnose the problem, etc...to no avail. The light for my Wi-Fi port is blinking green. The light for my ethernet cable (running to the PC) is solid green. On my computer, it says "Unidentified Network - No Internet" for my ethernet connection. Any help/advice would be greatly appreciated. Be forewarned - my "expertise" on these matters is completely non-existent. So the simpler you can keep the explanations, the better it will help me! Thanks so much.Solved1.5KViews0likes5CommentsGS308P left yellow LED blinks slow. No Internet Connection on this port
Hi everyone, what could be the reason when the left led blinks Slow and rythmically (not the fast flickering when there is Traffic)? I have No Internet Connection on the TP-Link EAP115 N300 Wireless Ceiling Mount Access Point that is connected to this port with the blinking led. I already connectrd another AP to this cable and No Internet there also. When i Plug another cable from another AP into the port the internet connection works fine. So for whatever reason there seems to be a problem with the cable that has worked for some years now. But is the blinking led maybe pointing to something else? Am i missing something? Thanks in advance!857Views0likes1CommentNetgear GS316PP scheduled reboot
Forgive me if this is a very silly question. Is it possible to schedule a weekly reboot cycle with this product? I imagine it being unmanaged would mean no, really not sure of the difference between managed and unmanaged switches. Thanks, JamesSolved976Views0likes1Comment
