billiloumez's avatar
billiloumez
Secure connection between two MS510TX
Hi everyone,
I'm currently planning on moving all of my servers and NAS systems from my appartment to the basement. There already is a Cat 7 cable leading from my apartment to a socket in the "tech room" in the basement. From there, I want to install a cable going to my own basement room.
Now I'd just put one MS510TX in my apartment and another one in my basement room and connect both via 10G on port 9. So far, so good. What worries me is the connection in the tech room in the basement, because the room is not locked. So anyone could just walk in, disconnect my cable and connect something in between.
Is there any way to securely connect both switches? My idea is, that both switches somehow authenticate against each other and only if they have a direct and secure connection with nothing in between, there would be any data transfer. Is this possible?
Thanks and regards,
Stefan
1 Reply
  • schumaku's avatar
    schumaku
    Stefan,
    Information security does start at the physical access level.
    Yes, there are - but these are off $$$ reach for most home, SOHO, or even SMB users. https://www.crypto.com/ -> LINK ENCRYPTION ETHERNET HC-8555 10G  8-)
    Anything is possible, however there is nothing in the industry standards for Ethernet interconnections. 802.1x port auth is for edge connectivity only.
ProSupport for Business
