ChrisJohnston
Jul 10, 2023Follower
Setting the password via startup-config for a NetGear GS324T running 1.0.0.16
Hello, I'm trying to configure some switch configuration automation via TFTP and upload a set of configs for switches using SNMP to trigger a TFTP load from a saved config. However, I want to be ab...
schumaku
Jul 10, 2023Guru - Experienced User
Not that it helps much here, just a warning: 1.0.0.16 was never formally released, in fact it's massively outdated; 1.0.0.17 was released mid of April 2019, beyond:
https://kb.netgear.com/000065117/GS324T-GS324TP-Firmware-Version-1-0-0-43
Warnings:
- Please reset password after upgrading the firmware or importing the configuration file from v1.0.0.38 or earlier version to v1.0.0.43 or a newer version.
- Please reset password every time if you switch the firmware and boot the device between v1.0.0.38 or earlier and v1.0.0.43 or newer
