switchfox
Jul 28, 2017Aspirant
SFP+ slots do not work at 1GE on GS728TXS
According to its specification the Netgear GS728TXS switch supports optical signals with line rates of 1GE or 10GE on ports xg25..xg28. All works fine for 10GE optical signals with SFP+ (single rate 10G and dual rate 1G/10G) on all respective ports, however 1GE signals are not working on any of those ports with SFP+ (dual rate) or SFP for 1GE . Link stays down. Seems the switch completely ignores the 1GE and I did not find any information in the HW/SW manuals on how to make that work. It is definitely not a cabling problem. Also the "Switching/Port configuration" menu has no speed selection of 1000M and AUTO obviously does not the job. Plugging in an SFP or SFP+ always shows a speed of "10G Full". The switch uses the latest firmware 6.1.0.36, Ports are configured as "Ethernet" (e.g. non-stacking,). Any guess what I missed and how the switch can be configured to accept 1GE optical signals. Thanks.
Hi John,
thanks a lot for your assistance. I now successfully made it work. It was a combination of several things:
-- Some of my SFPs (although compliant to 1000BaseSX/LX) are not working in the GS728TXS for whatever reason-- The dual rate SFP+s are always used at 10GE and the GS728 obviously cannot be configured to use them at 1GE
-- The optical RX power sometimes was accidentally in the overload region.
==> Would have been very helpful if the GS728 Web GUI (e.g. in the switching ports list) showed the RX level
of the plugged in SFP or even other information contained in the SFP-internal EEPROM or at least
LOS/Overload status.
In conclusion this is the "Accepted Solution".Thanks again for your help
Kind regards
Switchfox
- JohnC_VNETGEAR Employee Retired
Hi switchfox,
Welcome to the community!
Smart switches will automatically detect if it is a 1G/10G speed. It will still be depending on the module that you are using. May I know what SFP module are you using?
- switchfoxAspirant
Hi John,
thanks for taking care of my question. Find below a selection of transceivers I used with GS728TXS
-- Finisar, FTLX1472M3BCL, SFP+, 9.95 to 11.3Gb/s, 10GBASE-LR/-LW ==> works
-- Lumentum, PLRXPL-Sx-S43-22-N, SFP+, 10.312 Gb/s, 10GBASE-LR/LW ==> works
-- Finisar, FTLX1471D3BCV, SFP+(dual rate), 1.25 Gb/s or 9.95 to 10.3 Gb/s, 1000BASE-LX & 10GBASE-LR/LW ==> works at 10GE but does not work at 1GE
-- Lumentum JSH-42L4DD1, SFP, 1.06 to 4.25GB/s, 1000BASE-LX ==> does not work
-- Lumentum, PLRXPL-VE-SG4-38, SFP, 1.06 to 4.25GB/s, 1000BASE-SX ==> does not workCould you provide some part numbers of SFP/SFP+ that are known to be working?
Are there special setting in the SFP EEPROM settings (SFF-8472) that are required?
Kind regards
Switchfox
