alogat
Jun 14, 2018Aspirant
GS728TX vs GS728TXS
Can anyone help me figuring out what the differences between GS728TX and GS728TXS are?
They are from two difference series but from their model numbers the seem very alike.
The price is almost the same.
What I can't see is if there are different features and so on.
Thanks!
- BretDAdministrator
The main difference between the GS728TX and GS728TXS
GS728TX has 2x 10GBase-T Ethernet Ports and 2x SFP+ Fiber ports https://www.amazon.com/NETGEAR-Stackable-10GBASE-T-Lifetime-Protection/dp/B00OZCFVVC
GS728TXS has 4x SFP+ Fiber Ports. https://www.amazon.com/NETGEAR-ProSAFE-24-port-Stackable-GS728TXS/dp/B00BWBBTMY
Hope this helps!
