alogat
Jun 14, 2018Aspirant
GS728TX vs GS728TXS
Can anyone help me figuring out what the differences between GS728TX and GS728TXS are?
They are from two difference series but from their model numbers the seem very alike.
The price is almost th...
BretD
Jun 14, 2018Administrator
The main difference between the GS728TX and GS728TXS
GS728TX has 2x 10GBase-T Ethernet Ports and 2x SFP+ Fiber ports https://www.amazon.com/NETGEAR-Stackable-10GBASE-T-Lifetime-Protection/dp/B00OZCFVVC
GS728TXS has 4x SFP+ Fiber Ports. https://www.amazon.com/NETGEAR-ProSAFE-24-port-Stackable-GS728TXS/dp/B00BWBBTMY
Hope this helps!
- alogatJun 15, 2018Aspirant
Thanks for the reply - I noticed the visual difference as well.
Do you know if there are any software and feature differences ?
It seems that the GS728TX is availble on Amazon 1½ later than the GS728TXS - I was wondering if there are hardware differences.
- LaurentMaJun 15, 2018NETGEAR Expert
Hi alogat
GS728TX is latest generation, part of S3300 stackable series. This switch can stack with any other S3300 switch.
GS728TXS is previous generation, and EOL by now. It used to stack with itself and with GS752TXS.
- BretDJun 15, 2018Administrator
My knowledge has been expanded! :)
