MartinEDV's avatar
MartinEDV
Initiate
Jan 08, 2021
connecting GS728TXS and GC728XP with AXC761
Hello,
I want to connect my two switches (GS728TXS and GC728XP) to work as one.
Simply plugging the AXC761-cable into some 10G-ports does not work.
I need some help to configure the port settings.
Greetings
  • Have reconfigured the stacking port(s) to plain Ethernet uplink ports on the GS7xxTXS as per the fine documentation, p.91 "Configure the Stacking Ports as Ethernet Uplink Ports"?
    This won't make a "work as one" as this combination can't be managed as a stack.
    Don't know if there are any other support limitations for DAC on the GS7xxTXS.
  • schumaku's avatar
    schumaku
    • MartinEDV's avatar
      MartinEDV
      Initiate
      Hello schumaku,
      the documentation was helpfull, now it works fine.
      Thanks
      Martin
      • schumaku's avatar
        schumaku
        Immer gerne, speziell bei Dingen die eben nicht so offensichtlich sind.
        Grüsse aus der Schweiz!
        -Kurt.
No content to show
ProSupport for Business
