MartinEDV
Jan 08, 2021Initiate
connecting GS728TXS and GC728XP with AXC761
Hello, I want to connect my two switches (GS728TXS and GC728XP) to work as one. Simply plugging the AXC761-cable into some 10G-ports does not work. I need some help to configure the port settings....
- Jan 08, 2021
Have reconfigured the stacking port(s) to plain Ethernet uplink ports on the GS7xxTXS as per the fine documentation, p.91 "Configure the Stacking Ports as Ethernet Uplink Ports"?
This won't make a "work as one" as this combination can't be managed as a stack.
Don't know if there are any other support limitations for DAC on the GS7xxTXS.
schumaku
Jan 08, 2021Guru - Experienced User
