gsatish
Jul 08, 2022Aspirant
Short Netgear GS110TPv3
i have connected a CC Camera to port g2, but i see message Short. i am very new to Manage Switches, and i don't understand this.. What does below mean? does it mean cable is faulty at 90-100 meter di...
Marc_V
Jul 08, 2022NETGEAR Employee Retired
Welcome to the Community!
You are right, The port detected a fault or short circuit or an electrical short exists in the cable. You can check the manual for more information.
HTH
gsatish
Thank you for your response,
But when i have tested with cable tester, the cable is good. i getting response on 8 wires in my Cat6 cable. does it still have fault?
