Hokerberg's avatar
Hokerberg
Simple VLAN between two Switches
I have two GS108T switches. I try to setup a new VLAN in addition to the default VLAN1. I want one port on the first switch to be a member of my new VLAN (called 10) communicating with a single port ...
  • Hokerberg's avatar
    Hokerberg
    Jan 15, 2017
    Thanks for reply. I have found the problem. It's kind of embarrasing. I had the trunk cable in the wrong port on one of the switches. Now my VLAN works just fine.
    Thanks again.
ProSupport for Business
