Mantariz
Dec 14, 2013Follower
Smart Control Center V1.1.3.1 not settings adapter.
Hi, Hoping someone can point me in the right direction. I just installed Smart Control Center to version 1.1.3.1, It does not keep the network adapter setting. Thus it is so far pointless. I'...
- Nov 18, 2015
Sorry for digging up an old thread, didnt notice until after I posted.
Incase anyone else runs into this problem and finds this thread, I was able to fix the problem, by right clicking on the Smart Control Center program and running as administrator. Then it is able save the adapter change properly.
Thanks
Chris
faceprofile
Dec 28, 2013Aspirant
Same problem on GS516 TP :(
- chammondPMLITNov 18, 2015Initiate
Same problem, it defaults to the wrong adapter in my system and it cant find any switches. I go to the adapter tab change to the right adapter and hit apply. The program says it needs to restart, I hit ok, it reopens with the wrong adapter again.
The program is worthless to me right now.....
Is there an ETA on a fix for this problem?
I am running Windows 10 64bit Pro with v1.1.3.2 of the smart control center
Thanks
Chris
Thanks
Chris
- JohnRoNov 18, 2015NETGEAR Employee Retired
Hello chammondPMLT,
Welcome to the community!
Thank you for your contribution, I have marked your response as a solution. This has been an issue when Win7 was launched, it was more of a permission issue and some of the features of the new OS is blocking the Smart Control Center. That is why we have recommended to turn off any firewalls for the meantime when using the Smart Control Center.
Thanks,
