networkbug's avatar
networkbug
Smart Managed Plus GS308E switch
Hello All.  First time poster to this community.  I run a small business and started out with just a router.  I would like to upgrade my network to include 2 wireless access points and a couple of IP...
  • schumaku's avatar
    Aug 09, 2019
    Welcome to the Netgear Community!
    Depends of what you want to achieve. In general, all Smart Managed Plus (GSnnnE[P[P]], XSnnnE) and Smart Managed Pro (GSnnnT[P], XSnnnT) are essentially Web manageable switches. The ProSafe Plus Config Utility and Smart Control Center have (mostly) legacy usage. Netgear does provide the Netgar Switch Discovery Tool for MacOS and Windows.
    I would like to suggest you looking into Netgear Insight solution especially as you want to add switch(es) and wireless access point(s) to your infrastructure. This allows easy network config and management from local and remote, using an App or a Web portal access.
    A small difference in the Insight Switches (GCnnn[P[P]]) line is that the switches are covered with a five year limited warranty and 90 days of free support, while the Smart Managed Plus and Pro come with a limited lifetime warranty and support (including the new GS cloud [Insight] manageable switches).
ProSupport for Business
