nicke20
Jul 11, 2020Aspirant
smart poe switch closing down ports
I recently bought the above switch to make my home network a bit neater, has a router going in and a ubiquiti cloud key plugged in running 4 wireless ap's it then has a bout 10 devices plugged direct...
- Jul 11, 2020
Tha'ts the classic Sonos STP/l2 loop issue - if all Sonos players are wired, disable WiFi...
FWIW: The L2 loop existed before on your unmanaged switches - but you have never realized there is a problem and the network failed to perform well.
schumaku
Jul 11, 2020Guru - Experienced User
nicke20
every day is a school day
thank you for confirming and giving a propper explanation to what i had found by the good old method of plug one thing in at a time till it falls over!
Thank you
