juergenbgrusa
Dec 20, 2022Aspirant
SNMP GS728TPPV2
Hello all, I would like to add GS728TPPV2 Switches into SNMP Monitoring. Unfortunately I did only find at System > SNMP > Supported MIBS BRIDGE-MIB ENTITY-MIB EtherLike-MIB IF...
schumaku
Dec 20, 2022Guru - Experienced User
https://www.netgear.com/support/product/GS728TPPv2.aspx#download MIB Version 6.0.10.14 as of writing
juergenbgrusa
Hello Schumaku, thank you very much for your reply. I already found this download resource. But the download is just a buch of .txt files. I'am not that confident how to implement them since RMM Software is asking for OID.
Thank you Jürgen
- schumakuDec 20, 2022Guru - Experienced User
These are the management MIB required. The OID is the starting point for MIB queries used by such tools. The start OID is typically referenced on the Web UI. All switches start at the similar point in the oid tree. if in doubt, start with .1. 8-)
