torbianchi
Mar 11, 2022Aspirant
Spanning VLAN en Netgear Switchs across Cisco devices.
I have severar Cisco 2960 Switches colapsing to two Cisco 4500 backbone switches distributed in a doeble star configuration. Recently I begun adding S3300 Netgear switches that work better with video...
schumaku
Mar 13, 2022Guru - Experienced User
Not a lot of information on the network the VLANs. Suspect we face just a problem with the configuration of the trunk ports connecting the switches. The trunk ports on the S3300 must not configured as stacking ports, the VLANs you need to interconnect must be defined as tagged on the trunk ports.
- torbianchiMar 13, 2022Aspirant
Thank you for your answer. Each S3300 switch has two trunk ports pointing each Cisco 4500 distribution switch. Each trunk port has only two VLANS, vlan 1 (administration) which is untegged and vlan 112 that is tagged. Those vlans are defined in distribution switches. Vlan 112 is defined in S3300 as Static. From ports of each S3300 we can read no only internet but other devices in other vlans; but they can't communicate between devices in vlan 112 located in different switches.
