sveinse
Apr 19, 2025Aspirant
SSDP multicast leakage across VLAN on GS308EP
Setup Switch is in Advanced 802.1Q VLAN mode Port 1-6 connected to VLAN 1. Port 1-6 untagged, port 7-8 exclude. Port 7-8 connected to VLAN 2. Port 1-6 exclude, port 7-8 is untagged. Port 1-6 PVI...
- Jul 01, 2025
If anyone arrives at this page:
I reached out to NG support, and the issue have been fixed. They have released a new firmware for the switch that can be downloaded here:
https://kb.netgear.com/000066737/GS308EP-Firmware-Version-2-0-0-5
brian20930
Jul 22, 2025Aspirant
Did this actually solve your problem? I noticed the problem today, found your post, found that my GS316EP had a firmware update that mentioned the same fix (though the version is 2.0.0.3). But after installing the firmware the problem remains exactly as it was. Thanks! This is very frustrating!
