SA2020
Dec 19, 2020Follower
Stacking GS810EMX switches @ 10GB
Hi, Is it possible to stack the GS810EMX switch? The way I see it, it would be wired like so: Asus RT-AX89X router 10GB base T port connected to GS810EMX (1) multi port 1 GS810EMX (1) mult...
schumaku
Dec 19, 2020Guru - Experienced User
You can set-up these connections as described - however this isn't what stacking means. Just scratch the term and go ahead, nothing to worry.
No rack mount kit - it's obvious a non-rackable format design intended to show open. Install a 19" tab instead, this should take two side by side.
