rand__'s avatar
rand__
DHCP Response not traversing stacked switches
Hi,
hopefully only another user error, but at the moment I am out of ideas again.
I have 2 S3300's (FW 6.6.17) [A1,A2] connected via stacking in 2 different rooms.
On one of the 10G Ports another switch (B) is connected via Trunk, on that switch a bunch of boxes are connected.
I have issues getting DHCP to work over the two stacked switches, all regular traffic (non broadcast i suppose fine).
Local DHCP within Switch B is working fine, as is DHCP only using A1 (have not tested "A2 only"), but not the routes  "Client ->A1->A2->B" or "Client->B->A2->A1".
I can see DHCP Offers cross the line reaching my DHCP servers (one 2012 DHCP, one linux based one) on each room, but no actual DHCP replies get sent back.
I have one client and one Server in A1, one Client and one Server in B (VMs)
I have setup port mirroring on the uplink port 1/28 (which is on A2 and connected to Switch B) and capture DCHP Requests from B->A1, but the DHCP Server on A1 does not see them.
I have set up a client on A1 requesting from B and can see requests arriving on B but the answer never arrives back at A1
So basically traffic flows as follows:
Client (in either room) sends out DCHP request, this get received by DHCP server in other room.
DHCP Server replies with OFFER, but OFFER never reaches Client.
I used wireshark/tcpdump/port mirroring to verify this behaviour but can't really explain it :(
Easiest would be to break the stack and just link them via trunk but that can't be it...
Any idea how to troubleshoot this?
Thanks
  • Alright, that is good! Thanks for clarifying.
    I think we will focus on one direction for now (not the music band :smileylol:). Since your Windows server will be the DHCP server in the end, we can use that one and leave the Linux one turned off/disconnected for now.
    I am not sure where the Windows server is connected, but let's just assume that it is connected to A1 in the stack and your client is connected to switch B. Connection flow is like this then:
    DHCP server --> A1-stack --> A2-stack --> Switch B --> DHCP client.
    You have already done some good troubleshooting with Wireshark. From my understanding, you have port mirrored and Wiresharked the link between A2-stack and switch B?
    - You see the DHCP discover send from the client?
    - You also see the DHCP offer from the server?
    - Hereafter, you see nothing further?
    Just to clarify how DHCP works:
    1. Client sends a DHCP discover
    2. Server sends a DHCP offer, offering an IP address to the client
    3. Client checks that the offered address is not in use by anyone else (gratuitous ARP)
      a. If the offered address is in use by someone else, the client won't use the offered address and sends a DHCP decline message to the server. Hereafter the client starts the DHCP discover process all over again.
      b. If the offered address is not use then the client will accept the address, by sending a DHCP request to the server. A request to obtain the offered address.
    4. The server will acknowledge to the client, with a DHCP ACK package, and then the server will register the DHCP entry in its DHCP binding table.
    So, we gotta find out exactly where this does wrong. That will be important.
    Let's try this:
    - Port mirror the uplink between A2-stack and switch B, as you have done already. Run Wireshark to capture the traffic on that uplink.
    - Packet capture the server as well, at the same time.
    - Packet capture the client as well, at the same time.
    So, we have 3 packet captures running now.
    - Now, connect the DHCP client to switch B and see what happens. Filter the Wireshark captures by: bootp. This is so that you only see DHCP traffic.
    What happens exactly?
    The client sends the discover. The discover reaches the server?
    The server replies with and offer? If so, does the offer reach the client?
    etc.
    As you have 3 Wiresharks running, you can see exactly where the problem lies. For example:
    If the server sees the DHCP discover and sends the offer and the client sees the offer but never sends a request --> then we need to look into why the client didn't send the request.
    or
    If the server sees the DHCP discover and sends the offer, and you see the offer being forwarded on the link between A2-stack and switch B, but the client never sees the offer --> then we have to investigate why the offer was not forwarded to the client, by switch B.
    etc.
    I hope that makes sense? It is a bit of work, but this will give you a much better picture, because until we have the full picture we can only make educated guesses :)
    Any questions, give me a shout!
    Cheers
  • Hi,
    Thanks for the detailed description. Very helpful.
    I need to get the obvious out of the way :)
    You have two DHCP servers. Those two are active at the same time? If so, they are in different VLANs? The reason for asking is because you should never have two DHCP servers assigning addresses to clients, within the same VLAN. It will cause a bunch of problems.
    So, before we dig any deeper, can you verify how that setup is?
    Cheers
    • rand__'s avatar
      rand__
      The usual mode of operation is only the AD DHCP to be active, the linux one is for troubleshooting only:)
      But of course the two are not active at the same time:)
      • rand__'s avatar
        rand__
        Also, this is all on VLAN 1 i.e. native/untagged traffic
ProSupport for Business
