Rauko's avatar
Rauko
Guide
Oct 25, 2021
Error: Missing JSON response.
A window with the message Error: Missing JSON response. keep popping randomly. its not the product of any interaction with the UI, it just randomly pops every now and then, really annoying.
  • Rauko's avatar
    Rauko
    Feb 16, 2022
    In may case, and after a million different approaches, the solution seamed to be forcing the router an Rx300 to use a 192 based IP. on setup it always auto changed to a 10 based IP not to conflict with my network. I let it do it but I imediatly log via de http://routerlogin.com/adv_index.htm address and change it to 192. It has been workign just fine for now.
    In any case, since Im here I have a rather offtopic question, is there any way of stopping numaos from asking me my log and pass every 15 mins or so when I have the page open? its a bit annoying. I want to monitor stuff so I have it open, but every now and then I have to confirm my credentials.
  • If you reboot the XR, do you still receive the error message?
    What devices are you accessing the interface from? A desktop/laptop or a mobile device?
    • Rauko's avatar
      Rauko
      Guide
      Ive tried everything!! it keeps poping every 30 seconds!
      The only things connected to the router are a Laptop PC and a PS5. I acces the modem cia my PC, a regular Lenovo laptop with nothing weird in it, in fact whe nI play I have ONLY firefox running.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What page(s) do you see it on? When did you first notice the issue happening? Are you connected via ethernet or WiFi when accessing the interface? Are you using routerlogin.net or the LAN IP to access?
