Steffi5
Jun 22, 2017Aspirant
Switch blocks EAPol packets despite EAPol Flood
Hi, I have a GS110TP without any special config connected to a managed Extreme Switch. I want to authenticate the clients behind the Netgear switch on the access port of the Extreme switch so I e...
JohnC_V
Jun 24, 2017NETGEAR Employee Retired
Hi Steffi5,
Welcome to our community!
You may try enabling the EAPol flood mode on the GS110TP as it is disabled by default. Please check the manual here(page 5-25).
Steffi5
Jun 25, 2017Aspirant
Hi JohnCarloV,
thank you for the reply.
EAPol flood mode is enabled, sorry if that wasn't clear in my first post. That's why i'm so confused.
Steffi
- JohnC_VJun 27, 2017NETGEAR Employee Retired
802.1X-based authentication requires a RADIUS server for it to work on your network. An external RADIUS server performs the authentication. When a visitor is successfully authenticated, traffic is automatically assigned to the guest VLAN.
Please check this article.
