SwitchDaniele
Feb 07, 2018Follower
SWITCH GS724T or JGS524E which choose?
Good Morning, I'm doing a domestic system and I need to choose a switch to send internet signal to all TV and to be ready to connect to a domotic system (domestic security, roller shutter, new genera...
- Feb 07, 2018
Hi Daniele
Welcome to our community !
The JGS524E and GS724T are different type of switches, the JGS524E belongs to our Smart Plus Series and the GS724T to our Smart Pro Series.
In terms of Hardware the main difference is that the GS724T has SFP ports that you can use it for fibre connections.
In terms of Software both of them are web managed switches and support VLANs, QoS , Multicast however the GS724T has more advance settings in the VLANs,QoS and Multicast and also supports SNMP ,STP and ACLs.
For an environment like yours I would recommend also to have a look at the JGS524PE that comes with 12-port PoE so you will be able to power on IP Cameras, IP Phones, Door Controllers, PoE lights .
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
schumaku
Feb 07, 2018Guru - Experienced User
Hi,
These are switches from two different classes: The JGS524E does come from the Smart Managed Plus series, the GS724T is from the Smart Managed Pro series. More features, more management options, SNMP support, ... on the GS724T.
-Kurt
