tc43
May 20, 2018Aspirant
Switch GS728TP: POE Admin enable/disable via SNMP
Greetings Community,
i need to enable/disable POE on switchpots adimistratively from remote. I cannot use the buit in feature like scheduling, hence i would like to go ahead with snmpset.
Wha...
- May 20, 2018
Hi Tc43,
Welcome to NETGEAR community!:smileyhappy:
We can use the public MIB POWER-ETHERNET-MIB to control PoE status through SNMP.
Please reference following screenshot to deploy.
May the solution help you.:smileyhappy:
Thanks,
Daniel.
DanielZhang
May 20, 2018NETGEAR Expert
Hi Tc43,
Thanks,
Daniel.
tc43
May 22, 2018Aspirant
Hello Daniel,
thanks a lot! I got it running with your hint!
Best regards!
Chris
