Beerke
Nov 23, 2020Aspirant
Switch GS728TPPv2 not working when connected to wireless bridge
Hi all, I tried others forums but to no avail .... we need to switch our security cams to poe system. Since the building is not ours we cannot use utp everywhere. Here is the basic setup of ou...
- Dec 17, 2020
Welcome to the community! :)
Just to verify. The GT-AX11000 is connected wirelessly to the 1st RT-AC67U then the GS728TPP is connected hardwired to the 1st RT-AC67U, am I right?
What is the IP address set on the devices? Are they all set to static IP Addresses?
Are there VLANs configured in your network setup?
What is the current firmware of the GS728TPP?
DaneA
NETGEAR Community Team
DaneA
Dec 17, 2020NETGEAR Employee Retired
DaneA
- schumakuDec 17, 2020Guru - Experienced User
Try one of these:
- Disable STP (or RSTP, or MST) and enable "Forward BPDU while STP Disabled", or
- Enable STP the switch and on all ports and set the prio (aka. Configuration Revision Level ) to 32768.
These typically fix strange issues with consumer style Mesh systems.
- BeerkeDec 21, 2020Aspirant
Hi DaneA,
Just dropped in to say a BIG THANK YOU! Your First suggestion worked like a charm!!
I had given Up to be honest.
For other users: setup is as described above. All gear has static I.P. and I have no vlans. Firmware Version V6.0.3.3.
Huge thank you again. you saved me a lot of hassle (and my wife a headache from me behaving like a child lol)
Beerke
