Rimsa
Feb 20, 2024Tutor
switch port isolation
Good morning,
I wanted to isolate the ports on my net-gear gs724ts switch but I can't do it so I'm stuck. I would like someone to help me please
Rimsa
Feb 22, 2024Tutor
Good Morning
I did port isolation but when I try to send a dhcp there are no dhcp frames passing through.
schumaku
Feb 22, 2024Guru - Experienced User
Rimsa wrote:
Good Morning I did port isolation but when I try to send a dhcp there are no dhcp frames passing through.
Good morning Rimsa
Tell us more what you have configured, or what you intended to configure. Some screenshots might help.
Back to the original question: Talking of Protected Ports, or of VLAN configurations (what can be tagged ports for trunk usage), or access ports for individual VLANs?
Security > Traffic Control > Protected Ports > Protected Ports Membership
or
Switching > VLAN > Advanced ...
While you mentioned some GS724TS before, how come the GS308EPP is tagged with each of your posts?
- RimsaFeb 22, 2024Tutor
There I created the vlan2then on Membership I can't do anything, I can't modify the parameters thereand I specify the ports I want on my vlan2- schumakuFeb 22, 2024Guru - Experienced User
Bienvenue Rimsa
Appears your modern browser is struggling on these very legacy Web UI design and implementation dating back from the year 2006 or so. This is how it is supposed to look, here an example of a (admit much newer) switch UI:
Worth a try would be to use e.g. Firefox or Edge (where Edge does come with a lot of legacy Internet Explorer compatibility when I have it right). You could use Internet Explorer mode in Microsoft Edge (available on all platforms supported by M$ Edge, including Apple Macs just in case.
Excellent - you have the PVID already defined for VLAN 2. Many users are struggling with this part of the VLAN concepts.
PS. So we are talking about VLANs, not the subject "port isolation" what is a very different beast in switch design, implementation, and management.
I just tried with another browser such as Firefox Chrome Microsoft Edge It still does not work
