Rimsa
Feb 20, 2024Tutor
switch port isolation
Good morning,
I wanted to isolate the ports on my net-gear gs724ts switch but I can't do it so I'm stuck. I would like someone to help me please
schumaku
Feb 22, 2024Guru - Experienced User
Rimsa wrote:
when I put internet explorer mode I got this result
Already tried to drop/empty the browser cache, and done a forced reload?
Rimsa
Feb 27, 2024Tutor
Hello I finally managed to configure the Netgear Internet Explorer mode
but I have a problem I'm trying to isolate 3 ports on my switch to be able to pass another dhcp but I can't do it I would like help.- schumakuFeb 28, 2024Guru - Experienced User
DHCP runs either by default on the same broadcast domain and IP subnet, and sometimes beyond the subnet on a DHCP relay typically configured on a switch.
- RimsaFeb 29, 2024Tutor
actually my problem is that I have a router (zyxel) then a level 2 switch (netgears) so in my router I send an ip 192.168.255.0 in dhcp then on the port of this ip I also send a vlan plus in my netgear switch I want to isolate 2 ports to be able to pass 192.168.255.0 and a vlan but I try but I can't, so I would like someone to help me do it. - schumakuFeb 29, 2024Guru - Experienced UserNothing one can do on the ubiquitous consumer and SOHO class routers supporting one LAN and IP Subnet only.
