pr1970
Aug 20, 2021Aspirant
Switch showing lost packets to router
Hi All, I`ve had this switch for around 7 months and i`ve been noticing when using my PC in video calls i get occasional freezes. I`ve installed Pingplotter and I can see regular (every 5-10mins)...
pr1970
Aug 22, 2021Aspirant
Thanks, ok so now i`ve tried another switch netgear 4 port and ran it for a few hours and not a single dropped packet.
I connected back the 16 port with exactly the same cables and removed everything and within 5mins i`m getting dropped packets.
So its definintley the 16 port switch causing it.
Aug 22, 2021Guru - Experienced User
I would check to see if you're still within warranty on your device.
Click on "mynetgear" at the top. register an account and the device. from there you can check warranty/contact support
