Steffi5
Jun 22, 2017Aspirant
Switch blocks EAPol packets despite EAPol Flood
Hi,
I have a GS110TP without any special config connected to a managed Extreme Switch. I want to authenticate the clients behind the Netgear switch on the access port of the Extreme switch so I enabled eap flood mode on all ports. Unfortunately the EAPol packets from my client are not forwareded through the Netgear Switch. i can see them in a wireshark trace on my client, but not in port statistics on the Netgear nor on the Extreme Switch.
Tested on Firmware 5.4.2.27 and 5.4.2.30
I'm thankful for any hint I can get on this.
Thank you for the reply. Yes I know I set up Extreme Access Control based on a free radius Server.
I tested again yesterday after a reboot of the switch eapol flooding is now working. I thought just applying the new config would do the trick.
