tonynsx's avatar
tonynsx
Luminary
Apr 16, 2019
Switch web gui
I have a XS728T and GS724TS.  I noticed that the web gui for the GS724TS is "old fashioned" compared to the XS728T.  I have to put my browser on compatability mode just so I can view the GS724TS web gui.  I'm using the same browser for both switches.
  • Hi tonynsx,
    The GS724TS switch is already EoL (End of Life).  There will be no future fix or new firmware that will be released since this switch has been discontinued.
    Also, I have one switch on VLAN 2, and another switch on VLAN 3.  What would happen if I connect a dummy switch to these two switches?  How would the dummy switch know which VLAN to use?  Would it be random?
    It depends on the ASIC (Application-Specific Integrated Circuit) of the switch, and the switch itself. New switches (with E such as GS108Ev3) will likely pass through (based on MAC table). On older, non-E switches (unmanaged switches), it would fail CRC and drop the packet. E-switches without VLANs may still be aware of VLANs and be able to pass them through.
    It is advisable that you should not deploy an 802.1Q unaware switch in a network wherein you have expectation of persevering 802.1Q traffic.
    DaneA
    NETGEAR Community Team
  • Also, I have one switch on VLAN 2, and another switch on VLAN 3.  What would happen if I connect a dummy switch to these two switches?  How would the dummy switch know which VLAN to use?  Would it be random?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi tonynsx,
    DaneA
ProSupport for Business
