Partime
Dec 19, 2022Aspirant
Timer Schedule Issue GS752TPP Smart Switch
GS752TPP / Boot vs.-1.0.0.5 / Firmware vs.-6.0.10.14 I purchased this switch for the POE capabilities for POE phones and AP's. We had issues with the phones, not switch related, so I setup a timer ...
JeraldM
Dec 20, 2022NETGEAR Employee Retired
Welcome to the community!
Just to confirm, are you configuring the PoE timer schedule on NETGEAR Insight or on the admin page of the switch itself?
If you're configuring it on the admin page of the switch, could you attach a photo showing the configuration of the PoE time schedule?
JeraldM
NETGEAR Community Team
- PartimeDec 21, 2022Aspirant
Jerald -
I do use the web browser interface on the switch itself. The attached picture is the time scheduler setup page you requested. The time that you see activates at 5:00pm and as I said before, if I change it to 17:00 it still and only activates at 5:00am. The start date is not when i first set this up, it is just the last time I reworked it trying to make it work correctly. It has worked this way for several years and through several firmware revisions.
Thanks,
Jason
- PartimeJan 03, 2023Aspirant
I need to correct my last reply. "if I change it to 17:00 it still and only activates at 5:00
am" is incorrect. I meant to state "if I change it to 17:00 it still and only activates at 5:00pm” which would be correct but (05:00) or (17:00) only triggers at (5:00pm). I have tried other time values just to see if they would work correctly. I have tested (10:00) and it works correctly so I assume (10:00 to 23:59) works correctly too, I know (17:00) does. I have not tested (00:00 to 00:59) but I have tested (05:00 to 09:00) values and they are recognized as (PM) not (AM). So it seems any time value starting with a (0) gets recognized as a (PM) value.Thanks,
Jason
- PartimeJan 31, 2023Aspirant
I have not heard back from anyone with any answers one way or another. Do I just need to call tech support to find out why my time scheduler is not functioning correctly?
Thanks,
Jason
