InternJoe
Apr 08, 2026Follower
Total Power Budget 83W but total load maybe 100W at power-on
Hi all, we plan to use Netgear GS305EPP for a new project. This has 4 PoE ports with a maximum power budget of 83W. All 4 PoE ports will be connected to a PoE device that can use up to 25.5W but ...
schumaku
Apr 08, 2026Guru - Experienced User
InternJoe wrote:we plan to use Netgear GS305EPP for a new project. This has 4 PoE ports with a maximum power budget of 83W.
Somehow you mixed up the specs of the unmanaged GS305PP (max 83W) with the GS305EPP (max 120W power budget).
Either way, I'm with stuart012broad : If your project requires more than this - even in a small margin - the PoE controller might refuse powering the fourth powered device requesting 25.4 watts.
Look for the GS308EPP instead. It won't kill your hardware budget - and you are on the safe and the supported side with your project.
InternJoe wrote:Is our use case OK for GS305EPP?
Probably yes. There is a max 120W power budget according to the GS305EPP data sheet.
PS Sorry, I had a 100W power budget in my head when initially replying here.
