The-Puzzled
Sep 22, 2023Aspirant
Trunk cannot pass untagged traffic
I have created a trunk port with the following VLANs 1, 110, 120, 130 It appears as though I HAVE to have an untagged VLAN set on the port also so I left it as 1 If I connect my laptop to a VLAN...
schumaku
Sep 28, 2023Guru - Experienced User
Have set the PVID for the VLAN you intend to run untagged on the trunk? The PVID does define the VLAN you want untagged frames assigned to.
