The-Puzzled
Sep 22, 2023Aspirant
Trunk cannot pass untagged traffic
I have created a trunk port with the following VLANs 1, 110, 120, 130 It appears as though I HAVE to have an untagged VLAN set on the port also so I left it as 1 If I connect my laptop to a VLAN...
schumaku
Sep 28, 2023Guru - Experienced User
Have set the PVID for the VLAN you intend to run untagged on the trunk? The PVID does define the VLAN you want untagged frames assigned to.
The-Puzzled
Sep 29, 2023Aspirant
I switched the type from Trunk to General and everything worked as I intended, strangely enough that was the only change I had to make so there must be some extra rules around the use of Trunk as opposed to General that I don't understand.
