debrahlu
Aug 29, 2020Aspirant
Trunk Port
I am new to VLANs, so please be patient. :-) I understand that if you mark a VLAN port 'tagged' it essentially means that that port will send/receive all VLAN data so I don't need to have 2 sepa...
- Aug 30, 2020
If the plan is to have to 802.1Q VLANs with two dedicated IP subnetworks, your router must support two [V]LANs and two IP subneworks.
schumaku
Aug 30, 2020Guru - Experienced User
debrahlu
Aug 30, 2020Aspirant
Thank you, again! I was able to set up the ethernet ports on the router and traffic was passing properly. My only remaining issue is that I can't get the inter-vlan routing to work, but that's a router/firewall issue I'm sure.
Thanks, again.
