SteveAlfstad
Sep 20, 2021Aspirant
Trying to uplink between two s3300 via 10 Gig SFP's but can't get it to link.
I have two S3300-52X (one is POE and one is not) with 10 Gig SFP's, when i put the SFP's in the switches the port show 10 Gig full on both and I can see the red light on both but they will not link u...
JohnC_V
Sep 21, 2021NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues with the SFP+ on your S3300s. May I know if you already tried to use the same SFP module to another switch or even try to use another 10G SFP on the same switch just to isolate? Please also try to update the firmware of the switch if it is still not up to date.
John
NETGEAR Community Team
SteveAlfstad
Sep 21, 2021Aspirant
Hi,
I have tried diffenent SFP's, all brand new out of the box. I did try the same one between a M4300 and a S3300 and they linked up without any issue I don't have access to other S3300 to try that. I just checked and the firemware is old so I'll try and upgrade that and check the outcome. I won't be able to do that for a few weeks, we run 24 hours a day execpt for Sunday's and I am out of town this Sunday so won't be able to get it done untill next Sunday. I'll update the post ones that is complete.
Thanks
