RNUK
Dec 14, 2020Aspirant
Tuya / Lidl smart home devices don't work when connected to GS724Tv4
Hi All, Got a strange one here.... bought a Lidl smart home device and connected it via my switch. It's a rebadged Tuya device. When I search for the gateway, it eventually finds it, but it can...
jipp
Aug 19, 2021Aspirant
Have you tried the STP settings? specifically BPDU Flooding = ENABLE
By default it is disabled, never had issues since,
I have a GS724Tv3 and when I first got some Google Home Wifi mesh devices, they would work and sometimes discover, but had horendous issues with meshing and disappearing from the app.
After much searching a post mentioned this BDPU setting, which is only needed on managed switches it seems, a simple dumb switch works fine.
I wonder if this affects the discovery issue you are having with your smart device?
