jearhart
Oct 19, 2016Aspirant
Two stacked GS752TPSB switches - no POE on switch #1
I have two stacked GS752TPSB switches. Switch #1 has no POE output. POE works fine on switch #2. Both switches are running firmware version 5.3.0.26. In POE configuration, power status for ...
- Oct 21, 2016
I haven't tried that.
I don't know if it is coincidence or not, but I just ran a cable test on most of the ports on the first switch. When I did that, POE quit working. Rebooted the switch and POE started working again.
Evans-o
Oct 19, 2016NETGEAR Expert
Hi jearhart,
Welcome to NETGEAR's online community!
If you can, please log into the switch managemnet interfaces of both switches side by side,
Then, try to follow pages 70 - 74 of the Admin manual attached here. You may notice something configured differently
Let us know about your findings.
Thanks
