jearhart
Oct 19, 2016Aspirant
Two stacked GS752TPSB switches - no POE on switch #1
I have two stacked GS752TPSB switches. Switch #1 has no POE output. POE works fine on switch #2. Both switches are running firmware version 5.3.0.26. In POE configuration, power status for ...
- Oct 21, 2016
I haven't tried that.
I don't know if it is coincidence or not, but I just ran a cable test on most of the ports on the first switch. When I did that, POE quit working. Rebooted the switch and POE started working again.
jearhart
Oct 20, 2016Aspirant
I did that prior to posting. They were configured exactly the same.
Just after posting, the second switch did the same thing as the first one...no POE output, status showed "Disabled". After rebooting both switches, they both started working normally.
JohnRo
Oct 21, 2016NETGEAR Employee Retired
Hello jearheart,
Have you tested the switch when it is not stacked? Try removing it from the stack and see if the PoE will work.
Thanks,
- jearhartOct 21, 2016Aspirant
- JohnRoOct 24, 2016NETGEAR Employee Retired
Hi jearheart,
That's odd. But I'm glad it's working now. Try and monitor it for a few days and please give us an update.
Thanks,
